Fill-Rite Hand Crank Locking
joeyandcan
I have a Fill Rite Rotary Hand Pump model FR112. After installing the pump, it worked great. A couple weeks later I couldn’t turn the hand crank. I took the pump off my tank, reinstalled and it worked. A couple weeks later, again, it wouldn’t turn. What is causing this to lock up?
Thank you
Welcome to the forum.
Sorry, but mine is a 12V so really can't give specific help.
Do you have a vent on your tank? It sounds like it may be encountering some sort of vacuum.
I can say that Fill Rite has great customer service. They had a rep that was on this site for awhile but hasn't been around lately (and I can't find the user name).
I'd get in contact with them and see if they can provide an answer.
Suction tube is touching the bottom of the tank ? , usually they are angled or is there a check valve at the suction that could be sticking .
What are you pumping with it?
If its gasoline it might be lubrication or corrosion issue expecally with ethonal fuel sucking up moisture affecting the aluminim or vanes.
Is the vent hole on threaded adaptor open it might be on base of pump also try taking the other bung on drum off or loose see if its still an issue.
I have a vented cap, and tried it with the cap off. I am pumping unleaded gas (87). I also added fuel stabilizer to the tank. I don’t think my tube is touching the bottom of the tank. I will check for corrosion.
Is this a new or used pump?
This is from Fill-Rite's web page.
Q: FR112 , it's brand new and crank won't turn either way, came with no instructions, does it have internal lock or something ?
Answers (1)
Fill-Rite Company
01/27/21
A: Please contact us at (800) 634-2695 to better diagnose your problem.
Thank you
I bought the same pump last year. Piece of crap pump only worked a few times on unleaded gasoline and it locked up in both directions. It came with zero instructions. I thought Fill-rite FR112 was a top of the line product.
Fill-rite has most of their manuals online
Enter FR112 in the search box to download the manual
