Re: Parallel Bateries.
Lead Acid batteries are about 2 Volts per cell and their specific gravity varies with the amount of charge. 2 disimilar batteries hooked up in parallel will eventually discharge each other. Sometimes it only takes a day! If you do have an application that requires batteries to be run in parallel, try to get ones that have the same manufacturing numbers and dates, right off the shelf, side by side. Gell cells are nice, and seem to be able to withstand a bit more cold than conventional liquid type Lead Acid batteries. But they are pretty spendy. If the leads between the batteries are long enough and provide enough resistance, it is possible to get dissimilar batteries to work on a limited basis. I recomended the Boat Battery switch, but there are also various Isolator relays available. They are supposed to be able to sense when the charge circuit(generator/alternator) is active and allow both batteries to get charged, then when the vehicle is not running it only allows you to use power for say a camper, out of one of the batteries, isolating the other just for starting the vehicle. I have one of these on my Snow Cat Hauler, a 94 Diesel that already had 2 batteries, to keep a 3rd battery for the winch charged up. Unfortunately the 3 battery had a slightly higher voltage than my original truck batteries and wanted to discharce them when the truck sat for long periods of time. I operate it by a manual switch now. As for the Battery Boat switch, I get them from Blanchard Auto Electric, which is a wholesaler that supplies auto parts stores all over the state. I just threw out their catalog, someone like Grote, listed over a dozen variations on the switch. One should be able to find it on the net. After trying varioius relay arraingements, isolator charge diodes, and boat switches I have resigned to the baot switch as it is simple and usually doesn't have complications.
