Daewoo solar 130-iii wont engage pilot cutoff.
dwoo130
My excavator has the pilot cutoff not engaging when the arm is locked down. I've switched out the fusebox witch worked for a while now its doing the same thing. Don't have any controls.
Looking for any ideas.
tonkeeparts
  1. Electrical Connections: Check all electrical connections related to the pilot control system for loose or corroded wires, connectors, or damaged cables.
  2. Switches and Sensors: Inspect the switches, sensors, and relays responsible for the pilot control system's operation. These components can fail over time.
  3. Hydraulic System: Ensure there are no hydraulic leaks or issues that may interfere with the pilot control system's functionality.
  4. Professional Inspection: If issues persist, consult a qualified excavator technician or heavy equipment electrician to diagnose and repair the problem accurately.
