Crispy Herb Chicken
Here's another wonderful chicken recipe, which I use a crispy rice cereal in the coating mix. The kind of cereal that goes... Snap! Crackle! Pop! For this recipe, you can leave the skin on, or remove it from the chicken. The melted butter helps to adhere the coating mix to the chicken, even without the skin. Prepared either way, the chicken tastes great!
Crispy Herb Chicken
1-1/4 cups crushed, crispy rice cereal
1 (.06-oz.) packet Good Seasons Zesty Italian Salad Dressing Mix
1 teaspoon dried parsley flakes
3-1/2 lbs. chicken (chicken legs & thighs) about 10 pieces.
9 Tablespoons butter
1.) Line a baking sheet (with edges) with aluminum foil, or line 1-(14-inch) pizza pan with the foil, and spray the foil with a non-stick cooking spray. (If you should use a pizza pan, be sure to line the pan in a criss-cross pattern with 2 layers of aluminum foil.)
2.) Preheat oven to 375°F.
3.) In a shallow bowl or 8-inch baking pan; combine the crushed cereal, salad dressing mix, and parsley.
4.) Melt the butter, then add it to a shallow bowl or pan. (You can melt the butter in an 8x8-inch baking pan in the oven).
5.) Dip the chicken pieces (with or without the skin), and one piece at a time, in the melted butter; then roll the chicken in the cereal coating mixture.
6.) Place the chicken on the foiled lined baking sheet. (If using chicken with the skin on, be sure to place the thighs (skin-side-up) on the baking sheet.
7.) Bake chicken in the oven for 60 minutes. "DO NOT TURN THE CHICKEN AT ANY TIME" while it's baking in the oven.
8.) Once the chicken is done baking, immediately remove it from the pan, so it's not sitting in any grease. Serve chicken on a plate or serving platter.
9.) Yields: 5 servings (2 pieces per serving)
I did italian seasoned chicken thighs last night for dinner but used Panko style bread crumbs as the base, which is also crunchy.
