I think that is what the Amish guy brought down to cut my wood with. Cuts like mad but too heavy to use all day.
Boys that cut wood for me on Saturday had those red Jonsered saws. They cut pretty dang good also.
Jonsered has 3 dealers within 20 miles? If so, I now have 3 dealers within the distance of me-to-you (give or take 20 miles). Great saws but as John said, no real marketing.
Husqvarna must have re-arranged their model #'s. Your 60cc on a 562 XP caught me off guard as I could have swore my 365 is bigger then that. I checked the specs and sure enough, the 365 has a bigger engine but they're running pretty much the same HP.
Looking over the specs, the 562 revs higher which puts it in the same range. If it is about the same, it's a great saw...
Just an update..... Sent the 390xp out to be ported and muffler modded. The 346,and372 will be following in short order .
I have two Husky 55 Ranchers and a 562.
Love them all.
Biggest issue I have with any of them is that they really heat up the chains fast if you aren't careful. Which then expand and jump the drive cogs.
That said, they always start and never bog.
Turn up the chain oiler ,and make sure the chain is properly sharpened .
If you are cutting wood with dirt in the bark, go with semi chisel chain .
It's real likely Your saws are carrying full chisel low kick back chain .
That's the way most come from the dealer .
I didn't know there was a different chain.
Thanks for the tip.
running both vids at the same time you can see the difference
Fixed my error and it is easy to see the power difference. I do believe the red ones the Amish were running were a bit faster.![]()
I thought it was because they know how to sharpen a chain.![]()
I have a Jnsrud I think 2044 with Turbo. .
I was wrong. I have a 2050 Turbo. And again a tough little saw. I thought I remembered 48cc. When the Turbo kicks in you can feel it.
On second thought , as that's a fairly rare saw and all , go to www.arboristsite.com/chainsaw/. They should be able to give You directions on where to go with Your saw .I was wrong. I have a 2050 Turbo. And again a tough little saw. I thought I remembered 48cc. When the Turbo kicks in you can feel it.
Mr thcri!
I just sent another saw in for tweaking . When it comes back , can I post before and after videos ? Or will I have to suffer your junsred turbo 989 posts yet again ?![]()
If you had a decent saw you wouldn't have to keep taking them in for tweaking.![]()
