I drove the Bombardier around today after topping off the trans fluid (noticeable leak)...and it runs like a champ. So....for about 5 minutes....I considered leaving it as is and running it until something lets go. But, knowing it's rusting out...and it deserves better....I started it's restoration.
http://i837.photobucket.com/albums/zz295/DD453/IMG_0516_zpsdazwuxdv.jpg
http://i837.photobucket.com/albums/zz295/DD453/IMG_0517_zpsyjnnnowl.jpg
http://i837.photobucket.com/albums/zz295/DD453/A3DE9156-823C-4685-89DF-D3D3EB3E9533_zpshsmj4s3f.jpg
http://i837.photobucket.com/albums/zz295/DD453/1EE2B00F-AF8A-4DB1-BC73-F3931107CC36_zpsxniytg30.jpg
http://i837.photobucket.com/albums/zz295/DD453/F00C4D12-54A3-43A7-9B98-4040E6021A82_zpsonbcz9ab.jpg
I removed the salt spreader and rear cover (needs a good deal of sheet metal work).....found the bolts holding the brackets completely rusted out (used a carbide blade on a Dremel ....worked like a charm to cut bolts off). Both radiators will need to be recored (fins flaking off)....but something I wasn't sure on : the tracks are rubbing on the frame...and have uniform gouges throughout. Possible these are the wrong tracks on the machine? A bogey adjustment that needs to be made?
I have the manual (received from Bombardier Museum in Canada)....I'll digitize and post for a "sticky" if there is no copywrite issues.
Having fun!
Bob
Having fun!
Bob
