Jphoenix
OK, here we go!
Got the Skidozer off the trailer today. Bought a winch, welded some angle on the trailer and bolted it up. 13,000 lb winch, should work very well.
Got it off down the steep ramps, those will be another project. Cleaned all the debris out of it, I’d already opened up the diff cover and found three chipped pinion teeth, likely going to be replacing the ring and pinion before this is over.
Engine turns over, but the wiring needs a complete overhaul. I’ll pull the carb off and clean it up, get it running tomorrow then pull the cab off for some bodywork.
More later as I start disassembly.
