dlmorindds
Junior Member
Nice job on the reinforcement, I had some cracks on my 601 but very minor ones.
Don't forget the rubber grommets for the wire going through the side of the engine compartment. Looks good![]()
Grommets and wire wrap on the way!!!
I really like the color of paint you used, very nice job!
! Now I can get the full wiring harness put together
Heres you a few more green dots.I guess two dots are better than one![]()
Great job on the restore thanks for sharing the steps & pics .
I reread this entire thread for the 50th time again this morning dlmorindds & cant find where you mentioned what you used for the coating inside the cab or the frame of the body itself .
Whatever it is it looks bullet proof , the black looks like it could be Por15 but I cant make out whats used on the inside unless its the same coating with another color over it . Any hints ?
Once again a great restoration .![]()
Cowby...pretty much the whole cat has either been sand blasted or soda blasted. A couple aluminum body panels have been replace. The interior was treated with bed lineer using the exterior body color. Also, the tunnel area both inside and out has black bed liner. On alot of the tranny parts and brake/clutch parts I have been using POR15. That material is probably the easiest to use and gives a good tough finish!
I've never seen glass installed like that with the filler strip to the inside. Was that the way is was originally done or did you request it done that way for a reason?
A lot of the older Thiokols as well as others had the glass sealed on the inside for a "emergency exit". If you were sumerged in deep snow or water, an could not exit the doors. Just remove the seal strip kick the glass out and exit , hard to do from the outside if trapped on th inside.(ARCTIC TRAINING) Most of the newer equipment has top escape hatches for this purpose as an option, if you think you may encounter this type of situation. On any window installation we do using the bead lock we still install the seal strip on the inside just in case., but prefer to use the one piece window rubber that is self-locking into itself and makes glass removal easy from either side. PS Very nice restoration and consider it to one of the top ones on this form. Bill
