1450 Brake Parts spec ?
rockhead
So the manual on my 81 1450 says it has a 'modified drum brake' on the drive shaft. Does anybody know what parts fit this ? It seems to have gotten serious drag that overheated it to the point where the wheel cylinder exploded :bolt: which explains why stepping on the brake does nada.
To rebuild I suppose I'd need at a minimum a drum, shoes and a wheel cylinder.
I suppose plan B might be to convert it to a disc ?
Showed pic of brake assembly to local parts store, they figure casting #'s will source the needed bits, possibly excluding the drum which I'm guessing will need four holes added for the u-joint connection.
We shall see . . .
Please post results of your search, I have a 1450 missing the brake assembly too and would sure like to add one.
Wellllll, they were much less enthused seeing the parts in person. Got a couple of sorta matches on the wheel cylinder and nothing else.
Building from the hub out it appears I may be able to adapt a 2010 BMW X3 disc and caliper.
Parts ordered, film at eleven :hammer:
Locate the center, overlay template, missed it by a couple mm, then ready for center punch and drill
Ruh roh disc is yoooooge, chop shop time, and then ... 1 (stripped) bolt away from self propelled again:drive2:
The caliper drops into place like it belongs there :clap:
The alignment of the backer and the caliper is amazingly close to just 1/4" plate:wink:
ohhhh and from fabricating shop of rude crude and lewd the caliper bracket
