VW engine filtration
Our snow master has an oil cooler as well. It is mounted over the engine so it draws air through the vents in the hood. I have toyed with the idea of moving it into the passger compartment so one can use the heat. The old VW van I had many moons ago had a external oil filter that taped into the same port as the oil cooler dose on our Snow Master. So it is a after market parts to install both a oil filter and cooler.
