Thiokol ignition switch
Rico
Hello I have a 78 Sprite …looking for an ignition switch and any help from someone that has replaced one…thanks Rico
I have swapped mine with a simple farm store type tractor switch. It was pretty straight forward. AUX power.
BAT power and ignition some what do one wire at a time and you should be good
If you want to keep the momentary starter button you can get a keyed 2-position switch that doesn't have the starter engagement position. Check Wiring Products 2-position keyed switch 24 amps at 12 volts. $28.93
