Sno cat build
lifeofwelding
This is my first post
My name is Chris, I am highly interested in scratch building a pisten bully 100 130.
I am mainly looking for information on hydraulics as I don’t know much about the subject.
I am interested in using a Honda 4cyl, turbocharged to get the low end torque for the hydraulics.
My main question is hydraulic pumps? Do I buy a small excavator pump? From what I have read is that some have an inline triple pump, two main for drives and the auxiliary for my blade setup….
Ps I’m 25 years fabricator welder, so this whole build excites me but the hydraulic intimidate me slightly.
Thanks for your time.
Hi, Welcome.
I would suggest the following books. You might find these elsewhere cheaper.
Fluid power is a big trade-off. it becomes easier to regulate flows but at the expense of efficiency. Some systems lose as much as 30% in heat. Some pump systems utilize a constant RPM with a variable intake valve to achieve dynamic energy control. Others use a fixed displacement pump/ rpm with a relief valve system. Both have merits, both have debits on the system design. Its much like the design between turbochargers vs superchargers. I'd search existing systems that do what you want and use that as starting point.
Did he ever get going on this project?
My $.02 is buy a skidsteer and repurpose the parts
