Mico Master cylinder bench bleeding?
  • Thread starter Thread starter Reddog
  • Start date Start date
R
Reddog
Guest
Sorry for the duplicate post, but after i posted the first thread, I decided this was a better place to put it.
I am rebuilding some Mico high pressure master cylinders on a 1201. According to the instructions included with the kits, there is a gizmo you hook up to the cylinder to bench bleed the cylinder. It seems to screw on top of the fill port on top of the cylinder over the pressure relief valve. I do not have this gizmo, nor can I figure out how to craft one. Anyone have any input on the correct bench bleeding procedure on these high pressure units?
Thanks in advance, Doug
