Imp 1450 Master Cylinder fittings
JKS
Currently trying to find new fittings for the master cylinders on the Imp 1450. It is a banjo style block fitting (part #0101444 from the Thiokol parts manual). The banjo bolt going into the master cylinder is 1/2" - 20 and the brake line in 1/4" tubing with flare. Has anyone found this item or a suitable replacement?
A lot of trailers use banjo fittings to go from 3/16" brake lines (tubing measured by internal dia.) with 3/8"-24 inverted flare fittings, to the caliper. This is one example, though it doesn't show the threads or thru-bolt size, you should be able to call them and find out.
http://www.pacifictrailers.com/trailer-disc-brake-banjo-fitting/
Or Google "brake line inverted flare fittings" for lots of results..
Good luck!
A p.s.: at the rear, I found a hydraulic hose & fittings that went directly from 3/16" brake line to hose, hose to slave cylinder.. eliminating several stock Thiokol fittings and possible leak points. I'll dig out the part numbers and a photo and post later..
