I am trying to design a heating system to harvest heat from the side of a coal stove and pump it to the basement one floor down. My concept is to build a thermosiphon attached to the side of the stove. The temperature on the side of the stove runs between 200 to 425*F. The siphon would consist of 4-6 parallel vertical copper pipes set in aluminum radiant heat panels placed against the side of the stove with a manifold pipe at the bottom and top. This would run to a 30 gallon storage tank to collect the hot water. Then a separate loop to pump the hot water in the tank to some type of hot water to air heat exchanger. This will be an open system with no internal pressure.
Some questions/concerns I have are:
Not building a steam bomb
Is there a way to calculate the heat harvested vs heat used by the air handler?
In other words will I need to set up a control to turn on and off the pump based on the temperature of the water in the tank? How should this be done?
I have no idea what type of hot water circulator pump to use or what flow rate I should look for?
i have no idea what type of air handler I should use. I was thinking about a radiator or heater core with a variable speed fan. Maybe something pre-made.
I'm not sure what type of electrical controls I need/should use.
Can I plumb the transfer loop with 3/4 pipe or would I need to go with 1 inch?
There are probably some questions that need to be answered that I do not know to ask.
I realize the design info is a little vague, I am still in the early planning stage and anything can be changed as it all is still only on paper. Rather than trying to post the entire incomplete plan, if someone has questions about the proposed setup ask and I will answer. Any help I could get in designing this would be appreciated.
