Kevlar
I have a 2010 Ford F-150 crew cab 4x4 with about 210,000 kms. I’m not impressed with this engine and the more I read about it I don’t think they have a good reputation. I had to do the cam phasers a couple years ago, and it sounds like almost every one has had to have that done, despite the dealer that I got to do it saying they never did any
. And now it has low oil pressure at start up when the oil is cold and gets better as it warms up, when it’s cold I can hear the top end rattling if I try driving it ( sounds like cam phasers again). From what I’ve read it’s possibly pieces of the tensioners that destructed when the phasers went and fell into the oil pan and are now blocking the oil pick up tube screen. Going to pull the pan here in the next few days and see what’s going on in there. If not it’s likely the oil pump, but the symptoms don’t point to that, at least not in my mind. I’m sick of this engine, mostly the crappy phaser design, it has decent power but not good on fuel.
If this engine is garbage, have any of you replaced a 5.4 with something more reliable instead of just putting in another engine and hoping for the best? I’d like the one going into the boat in that other thread but that might be a little overkill
Just kicking some tires, I like the rest of the truck, just not the motor.
