Posted by: gmweiss
Description: Additional Specs, Equipment and Information: Specs Keel: Centerboard Engines Engine Brand: Volvo Penta Engine(s) Total Power: 50 HP Specifications •Length Overall: 38' 2" •Length Waterline: 32' 1" •Beam: 12' 8" •Draft: 3' 2" Board Up; 6' 8" Board Down •Displacement: 24,000lbs •Sail Area: 858 Sq. Ft. •Fuel Capacity: 80 Gallons •Water Capacity: 140 Gallons Construction and Layout The hull of the Kadey Krogen Cutter is of fiberglass sandwich contruction with closed-cell PVC foam core; heavy hand lay-up using mat and roving. This state of the art construction is of the most enduring and safest float. The composite structure serves both as a buoyancy material and shock, sound and temperature insulator. It rides quiet, increases impact strength and eliminates condensation build up inside the hull. Ballast is 7,000 lbs. Cockpit, bowsprit and cap rail are teak. The cockpit seats and sole lift for extensive storage. All cabinetry, joiner-work and paneling are teak. Teak capped beams thoughout. Saloon, galley, and stateroom soles of teak and holly. Standard Rig: jiffy reefing mainsail, club foot fore-staysail, hanked on genoa. Guest stateroom is versatile and accommodating with two large single berths that convert into a comfortable double with the cushioned "vee" insert. Hanging locker, storage lockers, and drawers provide abundant storage. Convenient private wash basin. Master stateroom, handsomely teak paneled, has full double berth with storage under, large handing closet and mirrored dresser. Also in Master Stateroom, Mirror folds downs to become chart table, Stainless steel wash basin in mica counter top. The Salon is full-beam width, bright with natural light, and comes complete with fireplace. Fore, aft and wrap-around seating has storage under. Teak drop-down table converts to a large double berth. Starboard table opens to dining space for eight. Forward of the Salon, the Head is sufficiently spacious plus separate shower stall with scrub seat. Hamper behind. The Teak-trimmed Galley is both attractive and artful in providing maximum efficiency and counterspace. Propane oven/range hides-out under hinged countertop. Double stainless steel sink; large pull-out trash bin. Fitted refrigerator and freezer. Teak companion-way ladder swings aside for access. On Deck •Wheel Steering •Compass & Pedestal •Aluminum Spars •Stainless Steel Rigging •Dacron Running Rigging •3 Lewmar Haylard Winches •Merriman Centerboard Winch •Lewmar #30 Self-tailing Main Sheet Winch •Lewmar #40 Self-tailing Genoa Sheet Winch •2 Samspon Posts •Bow Chocks •Stern Chocks •4 Mooring Cleats •4 Dock Lines •Genoa Sheet Tracks •200 ft. Anchor Rode •Anchor-35lb Plow Type •Double Life Lines, Stanchions, thru-bolted w/gates •Bowsprit with 2 Roller Chocks •Roller Bearing Traveler on Main and Forestaysail •Stainless Steel Bow Rail •Stainless Steel Stern Rail with gate •4 Bomar Hatches •3 Nicro-Fico Cowl Vents •3 Venturi Exhaust Vents •3 Dorade Vents •9 Opening Bronze Ports •Teak Companionway Sliding Hatch Mechanical The engine compartment is insulated and readily accessible from all sides for servicing and routine maitenance. Engine: 50 Hp Volvo Penta Diesel Generator: Shaft: Stainless Steel Prop: 3 Blade Bronze; 18' Diameter Muffler: Fiberglass Fuel Tanks: Stainless Steel Steering: Edson rack and pinion 28' Teak Wheel, stainless steel "Destroyer" outer ring Rudder: Fiberglass with protective skeg under Controls: Morse single lever type Electrical The same expertise, care, and thoroughness required of Jim Krogen to meet the rigid standards established for commercial craft are evidenced in the excellent electrical system of the Krogen 38. It is exceptioinally reliable and virtually trouble free. Electrical Components •Batteries - Heavy Duty Starting; Heavy Duty Ship's Service •40 Amp Battery Charger •Battery Volt Meter •Battery Box-Fiberglass •Electrical Panel - AC & DC metal lined with circuit breakers •Circuit Breaker Distribution Panels •Complete Bonding System for electrical grounding •Lightning Protection •Receptacles - 9-12 Double Receptacles located througout (110V) •Lighting System - 12 V DC •Dockside Circuit - 110V AC •Navigation Lights •Anchor Light •Spreader Lights •Lights Auxiliary Systems •Copper Piping - Insulated Hot Water •Hot and Cold Fresh-Water Pressure System - (2) 70 Gallon Stainless-Steel Tanks •Hand Pump Toilet -appoximately 25 gallon holding tank with by pass and pump in event of no discharge station •Hot Water Heater - (AC and from Engine) •All Sinks and Basins of Stainless Steel •Shower Sump Pump •Deck Hose Connection for Washdown
Boat Loans By Excel Credit.
More...
More...
