Hi all, I bought this machine last fall for winter transportation to the mountain cabin. I did a quick maintenance ( fluids, grease etc.) and a mechanical inspection. the 6cyl. ford runs good no smoke, noises or missing. The trans works as it should as well as the oc15 rear end. Also 1- drive sprocket was changed out for a better used one. I put 4- 20 mile trips on it last winter without issue except some vapor lock on the first trip that has been resolved. Track belting is in good shape without rips, checking or rot. a couple grousers need repair or replaced. The tires are good with the front ones foam filled. In my opinion the drive sprockets could last another season but are warn. mechanically it is in pretty good shape. the frame is ok but the body and rear deck have a lot of rust. I bought a tucker with a drive on hauler for next season as my wife can drive it opposed to the skid steer she can not so I'm going to let this rig go with the trailer and international 4700 to pull it with if needed. Cat- $7000.00. trailer $2500.00 and the truck $8,000.00 I will sell the cat without the trailer but not the trailer without the cat. any questions or more pictures just ask. Marty
