More progress on the transition duct. I got the complex bends done and the bulkhead that goes down to the bottom of the tunnel to prevent hot air from flowing forward under the engine. I just have to make the right side panel and the top cover. Fortunately I didn't screw up any large parts, only small ones.
I have some engine compartment insulation to put on the inside and it will be ready to paint.
I am going to use a hand throttle mounted on the angled cover. This thing is more of a tractor than a car and with a governed engine I think a hand throttle would work better.
The bottom of the lower bulkhead will be retained by two angles riveted to the belly pan that will slip over and sandwich the bulkhead without the need of fasteners. It has a rubber seal on each side that contacts a frame member.
Another couple of days and this part of the job will be done.
