st 3025 track adjuster washer
Cidertom
Chionophile
One of mine is on Mt Hood some where. Does anyone know a commercial source / part number? Or am I back to the lathe?
Did a quick search in the usual parts houses and nothing came up. None of the alignment washers I found had the correct dimensions.
mbsieg
awful member
can you post the parts diagram pic of it? and dimensions I have a lot of parts I can look through.
Cidertom
Chionophile
couple of photos for reference.
its back to the lathe had the same problem I used a flat washer for years befor I found one that worked
dep6113
sorry the link didn't come across right
the item is listed as
Z9462SET Spherical Washer, 21/32 ID x1 3/8 OD, 1 Pr
Cidertom
Chionophile
That spherical washer: close, but no win (thanks anyway dep6113). I think it would take as much to bore it out as to do from scratch. I should be able to find it as a part somewhere.
When the tire came off the rim, it allowed the wheel to go far enough back to let the adjuster come free. Groan
Dr. Zaugg
Kassbohrer used a washer like that on the PB 170 and early 200 models.
Seems about the right size too. I have a bunch of them somewhere but so do they.
