Snow Trac Rear Wheels + Rims
SnowTrac Hunter
Made a day trip to the cabin to verify dimensions for front outer drive sprockets. (Recorded dimensions in separate thread.)
Discovered that large rear rim on drivers side was cracked and broken badly. Need to replace and purchase a spare. Most likely was caused by PO replacing studs with bolts and holes wallowed out by loose bolts.
Does any one know of replacement rims and tires? Can I swap the hub to a 6 hole and a standard wheel?
Thanks,
Joe
if you have the stamped steel wheels they were supposed to have a washer under the nut or a nut with a flared base to spread the pressure. if you have composite wheels tere are supposed to be steel cones that insert between the nuts and rim. the last question is do you have 6 hole wheels or 4 hole wheels
JimVT
is it a crack from the hole to the center? I had the same happen. it's very hard to find steel wheels . been looking myself.
jim
Cidertom
Chionophile
I've been looking as well, for the 6 lug variation. Tried a "custom wheel shop " and they declined. Still want one.
CT
SnowTrac Hunter
It appears that I have one of each. They are both 5 hole rims. One has a piece mark of ST35A. It had cones under the lug nuts.
One had a Telleborg 6.00x100, the other had a Dunlop Sports D739 90/100-16 52M tire.
SnowTrac Hunter
I was thinking maybe a trailer tire/rim would work if I swapped out the hubs. Don't really care how many lugs it has as long as it works.
SnowTrac Hunter
I caught mine with one small crack running out from the lug nut. I had it welded good.
then managed to find one steel.
some say it was torqued wrong.
PO had swapped out the studs with long bolts, washers, and double nuts. I noticed this awhile back when it was wobbling, but the holes were already wobbled out. I have barely put 30 miles on it since I bought it. Seems like I spend more time broken down than up and running.:ermm:
PJL
Why people do that I'll never understand. I acquired a military surplus diesel John Deere Gator that someone used regular bolts instead of the tapered wheel bolts. Ruined all the wheels.
