Progress on IMP
hansoni
Been busy the past couple weeks with some time to spend on the IMP. Floor is down and cage built for the cab. Should get most of the sheet metal on this week. Layout for seating and mock up of windows and a cardboard gas tank thats being made now.
300 H and H
Looking good!!!
Your on the home stretch, winter is coming soon..
Hope for some snow soon....
Av8r3400
Gone Flyin'
Outside the box question:
Is there ever any consideration to roll over protection? Your cabin looks very well thought out, but if the vehicle ever goes over it looks like it will crush easily.
hansoni
I may still put a roll bar on the inside somewhere around the middle. Did they come with roll bars from the factory? Do they roll?
jkp2
I think I've seen this IMP before. Did you buy it in Otisfield? They had 2 of them, I bought the other one a couple of years back.
I like the full cab, nice work!
hansoni
It is! Thing was so ripped apart we had to re-build or replace a lot. Building a hydraulic steering system now.
I sent ya a pm
Steve
Restless
Am anticipateing a like project were did you access your rivets they look like a perfect match... thankyou for shareing your project pics ..
hansoni
I went through just over 1000 rivets. Got them at MSC or Grainger. I built the cab similar to how the rest of the machine was originally built with .050 aluminium sheet and overlapped the roof panels on the sides and back and used chalking on all the roof framing before putting down the roof panels. I used 3" spacing on the rivets just like the machine had already staggering them where I could. I used 2" spacing on the center roof panel where it overlapped the others.
hansoni
Back from paint and dry fitting a few things before nailing them down. My son and I have had fun with this project and hope to have it running by the end of the week.
Glass should be in this week too.
NE-Iowa
Congrats and an amazing Job on the Imp!
Frederique B.
redsqwrl
Shaping up nicely!
question, can you pull your radiator straight up through that hole in the hood?
that is a great Idea.
sheep_mtn
Looking fantastic. Did you replace your springs too? Got a good part number/supplier for a match?
hansoni
Yes the previous owner had cut the hole big enough to lift the radiator out. They had also switched over to an electric fan and they both don't fit unless you load both at the same time the fan through the front. We did replace all the leafs with new I have a drawing somewhere.
Steve
hansoni
Here we are at about 90 percent complete had it out this weekend running the kids around the yard. Looks like we could actually get some snow tonight!
Track Addict
Nice job. We got about 8" in Mass today. Hope you get to get it snowy new few days before the big melt!
Snowgeorge
Great looking imp
I'm the new owner of a 72 imp and want to put a muffler on the exhaust currently it is straight piped o under the passenger door. I was thinking of turning the corner and running it out the back with a glass pack any suggestions
Snowgeorge 72 imp
undy
any suggestions
Snowgeorge 72 imp
Sure.
First off, I'd suggest starting a new thread about your own cat. It keeps things a little easier to follow. People will post advice to you on your thread, and this guy's thread stays a bit more on-topic.
Second, I'd suggest tacking on a photo of your cat. Yes, we've all seen pictures of an Imp before. But we're all voyeurs and want to see more. Sort of the old expression about "you'll catch more flies with honey...". The more honey, the more bees.
:brows:
Third, do you want a muffler or a glass-pack? From my experience as a kid, they are not synonymous. Maybe it was my accelerator foot, but glass-packs never did much muffling where I was.
:whistling:
Scotg1107
I'd love to see some more info on your Hydro steering setup do you have any pictures of it and do you care to share some info about it?
Thanks
Scot
hansoni
We used a small belt driven Victor pump mounted on motor with a left and right solenoid valves actuated by an electronic joystick. I have the PSI set at 400 with a return flow gate. 6 gallons of ATF. Two small hydro pistons in the back that the flow is adjustable for speed. I used a return spring similar to the stock ones just a little heavier.
Here is a sketch of how it works and a pic of the pistons in the back and a partial look at where I mounted the solenoid panel in the tunnel.
turbinator62
Site Supporter
I see a couple of issues that could be a concern:
1. With solenoid valves the brakes are either on or off. I have found that when driving my cat, which has the same differential/brake unit as yours, that I make a lot of fine adjustments to the steering. Especially when traversing a slope as the cat will always want to turn downhill. Brake application while traveling along can vary from minimal to maximum and everything in between. With a non proportional system, you may find your steering to be very jerky and have difficulty with overcorrecting. With the high grousers you are using, this could put a lot of stress on the drive system. The only time I use full steering force is in a tight turn and even then rarely. Most of the time it is just small light momentary pulls on the levers.
If you are in fact using proportional hydraulic valves then this would not be a problem, but gets way more complicated with amplifiers, feedback and gain control, etc.
2. With a dead engine, you have no brakes or steering.
I have a lot of experience in hydraulic control systems (machine tools and aircraft) and just wanted to make you aware of potential issues with a non proportional steering system.
Cidertom
Chionophile
The way I avoid this on my tractors, is use either a flow restrictor orifice or a needle valve. The issue then becomes that when you want a full cylinder, you are still stuck with the slower action. I've done solenoids and the trick is getting the balance between flow and speed to achieve what you want. If you really want the electric over hydraulic, you might need a second circuit that trips when the joystick is at extreme, with no restriction. "wham" you be at full brake on that cylinder. But that adds a lot of complexity that I wouldn't want.
Great thought project
hansoni
Had her out yesterday and everything worked great. Steering is flawless and just like with the levers you can moderate the turn with the joystick. Despite the high grousers we didn't break anything and had awesome traction up some steep uphills and no problem sidehilling.
