Had what looked Iike a slight oil leak from the valve covers, so ordered new gaskets. While I'm in there....took the time to paint the valve covers in something other than rust AND might just as well adjust the valves. Uggh, a bit of a PITA since access to the front of the engine in order to turn the crank is difficult to say the least. Dog house comes off, alternator comes off, ratchet and 11/16" socket snaked in between the fan blade and the crank pulley in order to rotate the engine.
So, searched the web and came up with some Saab V4 instructions for the valves. Been a long long long (did I mention long) time since I last adjusted valves on a vehicle but no problem. All but one were too loose (no surprise) and one exhaust valve had almost zero clearance (no bueno). .014" intake, .016" exhaust.
All good now, purrs like a kitten. Tomorrow I'll check the ignition timing @6°btdc while I still have a very narrow window of access laying on my stomach on the passenger floor and squinting beneath the alternator for a glimpse of the timing marks.
Here's a link to the Saab manual I was using.
Adjustment Of Valves; Installation Of Valves; Valve Numbering; Valve Adjustment - Saab V4 Service Manual [Page 140]
Saab V4 Manual Online: adjustment of valves, Installation Of Valves, Valve Numbering, Valve Adjustment. Set The Mark On The Pulley Immediately Opposite The Dead Center Mark On The Transmission Cover. If The Crankshaft Is Turned Slightly Back And Forth In This Posi- Tion, The Rocker...
www.manualslib.com
