Yeah buddy....FINGERTIP CONTROLS
Still thinking about using the rear disc brakes though.
I like the idea of a separate system that applies full and varied brakes.
In the event of an inexperienced operator in command, the natural tendency in a sketchy situation is going to be...STEP ON THE BRAKE PEDAL
The vans brake system will still be fully functional and just lengthening the hydraulic lines and a little bit of work will get the system fully operational as a backup.
Unplug the ABS unit and remove the lamp in the dash.
This sucker will be annoying as it will not see signals from the output shaft sensor or the wheel sensors.
Unplugging the ABS will allow the brake system to function just fine to do whats needed.
The trans park lock will still be usable as well.
With the low gears in the butt end there will not be much tension on the park pawl.
Using the trolley valves will really simplify the hose s needed to the operator station as well.
Black line...Supply air
Blue line...Left side relay valve and air chamber
Yellow line...Right side relay valve and air chamber
Two 1/4" lines from the hand valves (Exhaust out to the engine bay)
Far simpler set up than I had before...
Also the trolley valve will allow for a gentle nudge on the steering to correct a slight direction change instead of a full on application.
Our old Cletrac used the C4 box and a slight nudge on the hand lever would give a little correction....
Anyway....I am very excited about this change order.....
Be nice to get rid of the lettering TRAILER BRAKE on the handles.....ah well
Maybe fill in the letters with JB weld and paint the handles black.....
Franken cat thing ya know..... Reminds me of the Johnny Cash song about his buddies car "One piece at a time"
