Briarpatch
I just recently put a new clutch kit in the tucker. It started out to be a challange trying to find the right parts. NAPA had every thing right except the clutch disc. It needed to be a 10 spline 13" with a 1.38" hub. They gave me a disc with a 1.5" hub and said it will work. I don't think so! I finally tracked down a LUK clutch number that crosses over to a car quest number (W05-047) Everything was correct except the throwout bearing did not fit the throwout collar. I had to order that bearing (SKF N1087) seperately and pressed the old one off and the new one on! Everything went together just fine and back on the trail again. The NPG 4 speed transmission is a tight fit as this particular cat was set up and ordered with a plow. A lot of plates were welded on just below the transmission. Maybe this information will help someone.
