Search cigar. At least a couple threadsToday is a Cigar day. I am meeting good friend at the cigar bar. Smoke a few; watch the Golf tournament; and solve all the problems of the world.
Does anybody else here share my love of cigars? We could start a new thread.![]()
Re: fence postsGot all the cattle moved in to the corral this morning to start their deworming treatment. I re-wired the lights in the chicken coop and worked on several other small projects. I need to make a list of materials for repairing the damage in the working corral. I'm planing on branding next week. There's a couple posts that I'll replace with railroad ties. I have a barrel of used motor oil and diesel that I'm soaking fence posts in. Even the pressure treated posts only last about 4 years here. I'm hoping that I'll get a few more years out of them if they're soaked in oil. Last night I used my tractor to dig some post holes, but could only go down about a foot and a half. I need to go down 3 feet. I'll chip away at them tonight, but first I'll start mowing the orchard. Several of the posts for the berries and grapes need to be replaced too.
Sounds like it would work. But I can't generate enough oil for all my posts. Right now I'm only soaking maybe 50 of my smaller line posts. How would you keep the oil in the bags when tamping the dirt around the post? I'm setting my corner posts in concrete, even the rail road ties.Re: fence posts
I never tried but I saw a video where the bottom end was put it a platic bag before placed in the hole. Filled bottom of bag with oil. Back fill around the bag. Top off with oil the top. Seems like it would work.
Ben
If wood ones are only lasting a few years, may be worth it to use a metal post.Sounds like it would work. But I can't generate enough oil for all my posts. Right now I'm only soaking maybe 50 of my smaller line posts. How would you keep the oil in the bags when tamping the dirt around the post? I'm setting my corner posts in concrete, even the rail road ties.
I do use metal posts, by the thousands. But my fence lines are so long that I need a wood post between about 50 or so T posts. Especially on some of these steep slopes here, the T post all end up leaning down hill.If wood ones are only lasting a few years, may be worth it to use a metal post.
Imagine if you will a metal fence post that is adjustable...I do use metal posts, by the thousands. But my fence lines are so long that I need a wood post between about 50 or so T posts. Especially on some of these steep slopes here, the T post all end up leaning down hill.
We have red clay here, and limestone clay. Sucks wooden fence posts up fast. Old motor oil has been out friend.Re: fence posts
Ben
We have some areas here with deep soil. In a heavy snow year the metal posts are pushed in the ground to where only a foot and a half is above ground. I have to go around and pull the T post out and replace it with wooden posts. Fencing is almost a full time job here. Right now I've got probably 3 miles of old fencing to pull out and at least 2 miles of new fence to build.Imagine if you will a metal fence post that is adjustable...
As the hillside moves, adjust the posts?
Probably cost prohibited maybe?
Ben
Congrats!.
In a few days it will be 44 for us.
Was a PITA but it’s done and I needed them to be able to turn the power up a little more. I like the different colors.
Then I would use a 4x4x1/4 metal post, between your 50 t posts, here on the ranch, I put an extra t post on the corners on an angle to the corner vertical post the weld it to brace the corners, you could do the same, makes it very ridged. Also all my gates hang on a 4x4x1/4 posts concreted in, no sagging gates.I do use metal posts, by the thousands. But my fence lines are so long that I need a wood post between about 50 or so T posts. Especially on some of these steep slopes here, the T post all end up leaning down hill.
Hope all is ok. Keep us posted!!A New health issue. My blood Pressure is crazy going form 160/106 to 115/ 70.
This oscillation happened several times over last weekend.
I am normally a steady 130 over 80.
I see a cardiologist next week.
I have no idea what these numbers mean, but it doesn't sound good. I hope you get it straightened out soon. Good luck.A New health issue. My blood Pressure is crazy going form 160/106 to 115/ 70.
