alryA
Used Tucker, in WI.. 1984 Tucker SNO-CAT (with drag)
Model 1342, S/N 3843666
2000 plus hours
318 Chrysler Industrial Engine
5 speed manual transmission
4 hydraulic connections
Wide 8’ Length 15’2” plus the pintle hitch
Weight 7500 LBS
$19,999.99
This is the complete list of items replaced/repaired on the Tucker within the last 18 months:
Rebuilt carburetor, new fuel pump and new fuel lines
New aluminum 40-gallon gas tank
New spark plugs, wires and cap and has solid state ignition
New exhaust manifolds and gaskets and new exhaust pipes
Rebuilt radiator
New hoses and thermostat
Rebuilt brake master cylinder
New hydraulic hoses for the drag that run under the unit to the back connectors
New LED headlights, yellow LED flashers on cab corners and new LED light bar on back of cab
New rubber bands on all the tracks, the cleats were inspected and repaired if needed, idler wheels have new races, bearings and seals and rebuilt drive cogs
All 4 axles were removed, and the differentials flushed, new differential seals and new axle seals
Cab was made watertight and driver’s seat was reupholstered.
add... https://northernwi.craigslist.org/hvo/d/ogema-tucker-sno-cat-groomer/7320377269.html
2000 plus hours
Weight 7500 LBS
$19,999.99
Rebuilt radiator
