Tye one on
I have a 1965 tucker 343a with a 318 Chrysler that has bent tubes on the front end. I was hoping to tweet them back into place but it's seeming like I may be replacing the housing all together if one can be found. As I disassembled the pontoon to remove it I'm seeing some worn parts that I will replace when I put it back together. There is one thing about the pontoon that has got me puzzled and I'm hoping one of you tucker guys will have the answer. If you look close at the bearing surface on the pontoon closest to the cat there is a steel insert in the Fiberglas that I cannot figure out how it comes out. When I grab it it is loose in the Fiberglas and will spin 1/8 of a turn and stop. It doesn't seem to be held in by anything and will not come out with light tapping with brass hammer. Are these replaceable? Maybe not. Thanks in advance for any info.
