Thank you for the information. I was able to order all the current parts I need for the engine from the place in Texas, we will see what shows up next week.My 1957 Kitten has the same Anglia 100e engine series 10HP. But it actually has 36 English horse power. Small Ford Spares in Malvern Worcestershire UK has all the Aquaplane high performance parts.
Thanks, it is coming along. I have Tucker stickers on order, once I get them here and on I will send some more pictures. Still have to grease the rollers, waiting for the grease to arrive, already have the new cordless grease gun and grease tip ready to go. Less than a month now to get everything done so I can take it to Joseph Oregon for the Alpine Cat Jamboree.Looking good...
Thanks for the tips, this will be my first roller greasing event (roller virgin). I did find that some of the cotter pins were missing. Also there are several links that must be a 500 series or something because they have longer pins and double end plates to take up the extra length. I also think the left steering linkage needs some fine adjustment, but it works fine so I am going to leave it for now. It just acts a little different from the right side and the right side seems to operate smoother.w
when greasing the rollers, not to much pressure, you can push the covers off the back of rollers and then you have a bigger issue to deal with, take it slow and just as you see the grease squeezing out the front side, STOP., all is good
make sure, the link pins and sprocket rollers are free and the like rollers turn easy, look at the ears of the grousers where the rollers bolt on, if, the ear is bent, it will need to be straighten so the roller face is flat on the rails, do not use heat to straighten, also look for cracks and welds that have failed
looking forward to taking it for a spin around the mountain
Thanks, I will have to measure them. I have eight 500 series pontoons, I will have to compare the links to the ones on those. But I have no 400 series other than what is on the kitten to compare to. Didn't know there were different link sizes. One learns a lot working on these cats, and I sure appreciate all the help everyone provides.I would guess you have 442/3A pins. Should be about 1/2" too long
400 A models / 1 inch rollers from a 500 are one in the same and so are the grouser links3/4 vs the A models of 1"
500 series may be another animal altogether.
Kitten looking great. K&N website should have a number of stock filters you can buy with varying carb flange id, width length, and outer dust filter to match.
just built it new, from scratch and just use the body panels so it looks like a kitten, otherwise you are just building upon failed designs,Looks like the major weak points in the Kitten drive train are the Tucker engineered brake and chain systems? Has there been any work done to improve them and make our Undercover Kitten into more of a ‘working cat’?
Napa has spark plug extensions or non-foulers if these are of interest.Well the kitten started up good this morning, so having a spark plug gap makes a big difference, who knew. I do think I am going to take some advice and add even one more copper washer on each plug to lift them just a little more and further from those valves. I am sure those valves are floating a bit, it is an abused 65 year old engine, valve springs are tired. Also, my son, and even I, drive that toy at well over 2000 rpm at times. Track on!
