ST4 back from the dead
Puckle
Hi Guys, great forum, some really useful information for the restoration of my ST4 I have just started.
I am having trouble identifying it as the data plate is missing and there are no key numbers, engine numbers or any other positive id tags - only unique number is gearbox (CA0976010) but I don't think transmission numbers were recorded and it may be a replacement anyway.
The dark green colour is original, and I think it may have started off as a canvas top as it has the tie downs on the body, but no military id anywhere or lifting hooks on side of bonnet - it does have folding lifting hooks on the chassis outriggers but I have not seen these anywhere else so may be home built.
It has big windows and low level wipers, transition brakes and small wheels so I would guess about 66/67 - I have e-mailed Kenth but without positive id there's not much he can do.
If anyone out there has more info, please let me know - I will update post as restoration proceeds.
Welcome aboard
There are many folks here that can offer great advice to help...
Bringing the old girl back to life is going to be a fun project indeed.
Enjoy the journey
it looks like it lived near salt water.
Jim, FYI, all of England is surrounded by Ocean/Sea/saltwater, everything is rusty over there.
welcome to the Forums, and good on you for taking on restoring the old girl, lots of great folks all willing to help, both in Europe and the rest of the world,
honestly, Snow Trac's are truly a world snow cat, and a great machine.
Puckle.
Welcome to the forum.
In the Island, I think the air and the dust are full of salt
Interesting.
1) The roof rack
2) The brakes. ( the drum is inside close to the engine).
and is not external, inside the Sprocket.
3) The hook, on the square tube for the leaf springs.
4) The three Argo 6X6, and the other ST4 in the corner.
Nikos
Puckle.
In the fotos I saw that is missing also the right side of the 2 band rubber trac.
Nikos
As for the dark green colour.
Inside the cabin the colour is red, the panels close to the engine are also in red.
The dark green (Brown green) became from the mix of the two colour ( red and green).
Nikos
Well, the bad news is magnesium crank cases are badly corroded so engine is beyond economical repair - plenty more on ebay though so I'll get a replacement. Also on the bad news front, variator spindle ST7688 is broken and front chain sprocket has been ground down after a bearing collapse and seal spigot is missing - I managed to braze on a collar of steel and turn it down to correct size though so that should be ok. Christer does have spares of ST7688 but I will attempt repair first as they are over £350
I agree on the soft top originality.
I think you have a pretty unique machine, it has many good parts. lower wipers and seat is consistant with a much later machine. the small wheel suspension is consistant with 66-67 but the upgraded front trucks or walking beams is something that came late as well.
It appears you have both braking systems. I would be curious if the rig has the high speed (optional ) sprockets or the standard tractor or normal sprockets.
a lot of times when rigs get combined it is to save them. other times smart people take the best of the different models as put together the desirable bits.....
Nice machine. to my eye it has all the good stuff.
It has standard 38/12 gearing but your right, it does seem to have a bit of a mix of parts - I guess something 50 odd years old gets altered quite a bit over the years - for example mine does not have diagonal bracing across the back panels and has the fuel tank on the right but I don't think it left the factory that way.
Another thing I've noticed is the reinforcing box section underneath and diagonal angle iron brace on the center outrigger - I've seen several machines with this exactly the same as mine but again I'm not sure if it was a factory mod or perhaps something Alex Maclarty did for the Scottish market?
I've sourced a replacement engine (1600 with new barrels, pistons, heads & big ends) from e-bay and have had the it running with the gearbox and variator on the workshop floor. The repaired ST7688 seems fine (I machined it off the flange, made a solid plug to go inside the spline'd section then welded and brazed them together. I turned the plug down to fit the flange and re-welded that back on, then finish turned everything back true including re-boring the hole to go over the mounting shaft)
The gearbox is jumping out of 4th gear but otherwise seems ok - no debris on magnetic plug and not noisy, so I will strip it down and see if I can just replace 4th gear synchro ring.
the cabin with rear windows could be handy.
one modification that has been done on that year is the newer disk brakes added to it.
you may fine pictures in this forum of it.
On a VW transaxle that jumps out of gear it is seldom the synchronizer at fault. The culprit is typically the operating sleeve that has excessive wear on the back-cut of the inner teeth.
The better parts places that cater to the offroad/VW market can provide the pieces.
Nice project!
I look forward to following your restoration.
looks like a later model cab with the early model 2 band track and undercarriage it may be one of those Irish machines that were built with left over aktiv parts
Yes, could be a mix of all sorts of parts - the other one for sale at MacTrax was ST4 669 and had small windows and high level wipers but large front wheel - its on e-bay at the moment.
I will strip box down luvthemvws and see whats up but your right, it probably will be the sleeve - struggling to find somewhere that sells that part in uk but will keep looking.
New brake parts fitted - wheel cylinders, master cylinder, shoes, hoses & pipes and gearbox stripped down for inspection. Unfortunately this had also sat for years with water in it and casing is virtually corroded right through around the drain plug - gear bearing surfaces are also ruined. I bought another transmission of E-bay which was in pieces so I could inspect all the parts and re-built this with the old variator parts. It is a much later transmission with a different main shaft and finer toothed gears - it also has thicker steel selector forks as well.
I'm now building it back up so I can test everything and sort exhaust route etc and will then strip it back down to sort out corroded body parts before starting to paint it - not sure what color yet, green like it is now, blue because I like that color, or red because they do look good in red.
the Fotos
Puckle;[B said:
20725385]It has standard 38/12 gearing but your right, it does seem to have a bit of a mix of parts - I guess something 50 odd years old gets altered quite a bit over the years - for example mine does not have diagonal bracing across the back panels and has the fuel tank on the right but I don't think it left the factory that way.
The gearbox is jumping out of 4th gear but otherwise seems ok - no debris on magnetic plug and not noisy, so I will strip it down and see if I can just replace 4th gear synchro ring[/B].
The repair of the variator spindle on the lathe (FOTOS)
Rebuilding from a piece here and there can certainly be a challenge...
Looks like you are getting a good start on it.
Great fun.
The hard work will all be worth it.....
Ha, yes, quick to get running but loads of work to do yet.
First time I've driven one of these and very impressed with design - very maneuverable and very light on the steering. Best of all it does not rip up the grass (my wife would have banned it from her horse's fields if it did!) - it does not even stir up the gravel drive when doing sharp 90 deg turn into garage, not many tracked vehicles would be that gentle.
Wow, your certainly giving it some round your yard, sounds great as well.
I have completed a few more tasks today, new bonnet frame rails made from galvanized electrical conduit and fitted new starter motor - a Wosp LMS 027, similar to IMI Hi Torque featured elsewhere on the forum, but 2kw motor with offset spindle so an 11 tooth gear can be used - really spins my 1600 up a treat. Its also easier and cheaper to get hold of in Europe than the IMI one.
I have also started to do the exhaust - as I will mostly be using this on off road tracks rather than snow I didn't want it under the chassis where it would get bashed. I've taken it out through the rocker cover inspection hatch and along the top of the frame rail and up the back panel to roof level. There is just enough room for 1 1/2" pipe to dogleg around the track. The flexible piece is easily removable so I can still get good access to rockers.
Starting work on the rust!
Most of the roof was salvageable, I've just had to replace some of the 25x25 box section and make a few new panel sections for the corroded bits on the curved sections - a compressed nitrogen cylinder came in handy to form the radius sections over and I made a small brake press to fold the lip sections.
By the time I had cut the windscreen and side panels into their separate parts there wasn't much left so I'm having to fabricate new copies of those
All I have to say is this machine is one of the luckiest Snow Trac's on the planet.
Lucky YOU found it! :clap:
