Snowmaster #1656 rebuild
So i felt odd hanging the engine out there too.... then i remebered class 11 baja racing class. They hang out off the trans axle and repeatidly pound the chassis for 1000 miles down the baja pennisula.....
All kinds of ag equipment have motors hanging off the transaxle too....
If the clearance is making you lose sleep go look at an imp driveshaft and oem gas tank. (We were standing around making millwright jokes last weekend at an imp that won a 1st place award)
" how are you going to fit a guard in that 1/4" space between tank and drive shaft ..... with a 1/8" wall pipe...."
The ford pinto excluded, these thiokols were built before america was encumbered with overthinking....
That's the way mine work, I have switchable one way valves in the brake lin
I’m going to leave it alone for now but I have a plan! I think I can sneak in a support member directly inline with the ej25 motor mounts to carry a little weight and torque. I’ll just promise not to catch sir more than once each month!😊 Thanks for the insight! On the clearance issue, there’s a tight 3/16” now, I’ll add a 1/2 link and I’ll be happy!
We have a dune buggy that came to us with a late bus transaxle holding a Chevrolet small block V6 and 200 lbs of weight added to the front axle. The engine was removed and scheduled to re-power a 1949 Tucker but the project stalled. I now have the V6 , a totally rebuilt TH350 and all the VW adapter pieces available. The dune buggy will be getting a much smaller engine and PP has the Tucker. The dune buggy is set for Mattracks and front skis for Sisters next year.😏
Steve and Cathy in McCall Idaho
If you wind up removing the drums from the driven sprocket, please take pictures of the drum for me. I'm recreating a braking system from scratch. When I got my cat there was nothing left of the original brakes at all I'm now wanting to try another version of home brew. Thanks,
As it turns out I will be pulling the brakes apart again but only to remove the hand brake bands. I’m leaving the driven sprocket and drum in place. I will take photos of whatever will be helpful. Are you interested in any specific detail?
inside of the drum if you are pulling the guts out. want to see how much of the drum is there and the clearances to the hub.
The id of the drum is 9”, od 9.5”, width of the drum brake surface about 1.75”. Let me know if you need more detail.
