Skidozer 252 GVW
JK3377
Does anyone know the weight of a 1980's 252 with plow attached? Just wondering if a 7000lb trailer would be enough.
olympicorange
…. according to one spec. sheet online....'' base vehicle weight''....6000LB. so add blade weight, full body cab, etc.... so you should be in the window between 6 & 7 K lbs.
Nort Woods
On a similar note, can someone tell me the GVW of a 1979 sv200? Looking to trailer it and want to make sure I have enough trailer. If you have width, length & height information I would appreciate that as well.
Thank you in advance!
Nort Woods
I have searched the internet and haven’t found a spec on the 200, found everything but!
vintagebike
I hauled our SV200 with a 6 way blade and extended 5 person cab from Seattle to McCall via Hwy 84 on a 8.5x20 9900k Carry-On deck over trailer behind a 2013 F150 5.0 4x4. Loaded with blade to the back. It did sway a bit on the mountain passes and will use a load equalizer with blade forward next time. Kept it at 65-70 the whole route.
Nort Woods
I hauled our SV200 with a 6 way blade and extended 5 person cab from Seattle to McCall via Hwy 84 on a 8.5x20 9900k Carry-On deck over trailer behind a 2013 F150 5.0 4x4. Loaded with blade to the back. It did sway a bit on the mountain passes and will use a load equalizer with blade forward next time. Kept it a 65-70 the whole route.
Thank you VB. Will the specs be similar to a sv252 other than the extended cab?
