Question for all you 601 operators out there
fritz
what is proper track tension on the 601s? I have been trying to track down a manual for this machine, but have come up empty handed so far
redsqwrl
I step on the track mid span. if the grousers spank the inside easy too loose. if they don't hit at all under my 200 lbs too tight.
having them equal and a tick loose is about right
fritz
copy that. Mine are on the way too tight side then if I understand you correctly. You're saying they should flex enough to almost hit the underside of the cab just stepping on them, is that correct? Or are you saying the inside of the grouser on the sidewall of the tires?
