Picked up a new ZTR
Does he charge by the season or for each mowing?
He mows about 1.5 acres. Every other week he also gets out the string trimmer and trims. $80 when he mows. $150 when he does both. Roughly $460 per month. Roughly 6 months per year. So roughly $2500/year.
New mower was going to be in the $6500/$9500 price range for something with extra wide wheels designed for slope mowing.
Haven't tried the new mower yet, but the older one I have can climb hills I can barely walk up without issue. This brand is known for their climbing abilities. Both have 12" wide tires so there's plenty of hill-climbing traction.
This mower isn't cheap... it retails for over $14,000. That said, even at $2500/year for someone else to do it, it'll pay for itself in 6 years. My old one is 22 years old and except for a clutch and regular maintenance items, it's run flawlessly.
OK, did my first mowing today. Didn't really need it so not sure I got the full experience.
Some thoughts/impressions.
- Ride was a bit bouncy. Took the air pressure down to 10 PSI which helped.
- The joystick control is a little sticky, not nearly as smooth as my old mower. Hoping this loosens up with some hours.
- This thing is heavy. Not nearly as nimble as my old one which weighs probably 500 pounds less.
- Because of its weight, you need to drive it differently. No flying into sharp corners. It's not forgiving if you pivot on a rear tire.
- It'll climb steep hills. I'm just not confident doing it quite yet, primarily due to I'm not used to the extra weight, width and center-of-gravity. My older ZTR climbs very nicely but it took me several years before it was comfortable.
Bump. I've used the new one for a season.
Love/hate relationship.
Love it for doing open areas. It's a beast when you run it on flat, dry ground. WOW (for this part of mowing).
Hate how much it weighs. It'll tear up everything if you're not careful. It doesn't like wet grass. It'll cut it but the machine weighs so much it tears up the yard easily.
Doesn't have the finesse of the old, smaller one. No way it can do tight areas and steep hills as it's just so friggin massive.
Punch line - I mow with both mowers. The old one for finesse and hills, the new one for the big areas. Never thought I'd need 2 different mowers.
Doesn't sound like you 'need' 2 different mowers, but since you have two, you want to use both. Why not sell the big boy and buy a newer one the same size as the 22 year old one?
I cannot even think about understanding this.....the more the merrier 😉
