I've looked at screw driver models even talked with some of the manufactures and they all are concerned about the environment I will be using them in
Here are a few ideas for you. http://qrznow.com/70-wire-antenas-ideas/Ki0ho any ideas about a multi band hf antenna for brutis I have enough room for my ts 140 in it
OK, I'm working on it. By any chance, do you have a 2 meter repeater close by?congratulations now pick up a fm radio and find a node in your area steerit to the Alaska reflector and give a shout out my radio has been on all day
yes I do have a repeater system here my node is simplex and I leave it connected to the Alaska reflector. a reflector is just a hub that lets multiple nodes communicate. so once you have found a node in your area either simplex or connected to a repeater it's a matter of disconnecting with a 73 command than re connecting with a 9070 command. the best way to find a node in your area is go to the irlp web site do a search with your zip code.OK, I'm working on it. By any chance, do you have a 2 meter repeater close by?
as I charge into the never ending search for the perfect antenna.
It was trial and error for awhile but I found your node. Talked with a fellow (sorry, didn't write his call sign down) who said he hadn't heard from you today. Asked him to pass 73's to you and let you know I'll try again tomorrow.
I'm going to start building a directional 2 meter band antenna next week. Nothing too fancy but it should give me 7 db of gain and help me hit the (semi) local repeater. Also good experience as I charge into the never ending search for the perfect antenna.
I will also be setting up a OCF Dipole next week and hope to get a little more active with DX. I've had my Yaesu for over a month and never even had a chance to use it! But that all changes next week!
Have to hunt down Jev and KI0HO too!
