Hi all new to the sight..
kenmcal
I pickup an old Cushmen Trackster. I was told the engine was bad and was removed. The engine had great compression so I reinstalled it got it running drove it from the back yard to the front yard shut it off. Three days later if fired right up wouldn't move at all I changed the filters the hoses to the coolers still no luck... My question is are these worth messing with or should I just pull the whole system out and re-power with hydraulic pump and motors. Looking at the manual is looks like it would be fairly easy just a little fabbing.
Pontoon Princess
Cattitute
great to have you join the forums
the preferred repower set up, Honda, lots of them done and well sorted out setup
good luck
kenmcal
Thanks for the advice. I get the Honda repower for the engine but I think the Transmission is shot too. It moved at first now its completely dead in the water will run but wont move. I am thinking of a whole new drive system.
Track Addict
It's probably the cdi ignition. Causes no spark. They also have points I believe.
use to be a guy who specializes in these. Think he closed.
