Finally putting some Imp time in, 'splain this to me
BoyToys
SUPER FF Supporter
If you're old enough you may remember pogo sticks. My Imp loves to do the pogo...front end oscillating up and down drastically when encountering whoopty-do's on an otherwise smooth surface. Might just be due to the heavy ass snow blade up front. What else could cause this? My guess: leaf springs are shot...say it's not so!
A good bit of it is the short track line so it comes by that naturally. Drop off your blade and run it to see if it makes it better.
I should try that. Dropping the blade is easy enough, but getting it back on a bit more challenging. I should eventually build some sort of stand to rest it on.
Put your blade down and shave off the moguls.
I angle it a bit and dump the snow to the low side.
Fwiw my green imp has a rear bumper made out of 1/2 plate. Its massive and cutts the porpoise-ing down a lot
Thanks for the replies. Seems to some extent normal I guess, exacerbated by the heavy plow sticking way out front, creating all sorts of leverage. My blade is 7 foot, heavy guage steel, appears home made, probably weighs 100 lbs. Would like to replace it with something thinner guage steel, or a composite of some sort. Perhaps a summer project.
Maybe next time I'm up at the cabin I'll remove the blade when done plowing my driveway.
This probably isn't going to go over well, but a two track machine on a trail with a washboard-like surface is constantly oscillating up and down. It's not a pleasant experience.
A few years ago snowcat buddy/partner in crime Scott (aka:The Gorilla) and I took a Tucker 1544 and a DMC 1450 out for testing. Same day, same conditions, it was a fair head-to-head comparison. During the day we switched machines a few times, and when the day was over we compared notes over a sarsaparilla, or two.
Both machines ran well and there were no mechanical issues affecting either machine. We agreed the DMC 1450 performed well (truthfully, it exceeded our expectations). I'll pause for a moment and say this was a modified 1450 in that it had extra wide tracks. But the ultimate question was "Which machine do you prefer" and we were both in agreement the Tucker 1544, with its four-track system was better.
At the 2022 Sun Valley Serenade (I think that's the right one) none other than the Infamous WBJ1 drove that DMC 1450 for a day, and his comments on the ride mirrored ours.
Honestly, it's the nature of the beast.
It is what it will be, the nature of the beast. I've only had it on a partially compacted road with about a foot of loose snow on top, so any lumps in the road will cause porpoise'ing. Just have to watch the road conditions ahead and slow down a bit so I don't get beat up inside the cabin.
Need to take her completely off road into untracked deep stuff. Sure to be a different story in those conditions I would think.
Maybe. But I have seen what happens when a Tucker crossed over a berm and the back of the front tracks tried to eat the cab floor and wall. Not good. Nor is a Tucker good in a none pine forest, meaning deciduous trees of the Midwest. Too tall to go under much.
Your milage may vary.
Kirk,
That’s certainly unfortunate about the damage to the Tucker cab. However, for that to happen the carrier (if one side was affected), or carriers (if both sides) had to be either damaged or modified. I’m pretty outspoken about taking Tucker to task for poor quality control, but if someone modifies or damages their machine, they need to be cognizant of any limitations until repairs are made.
As you probably know, the carriers on Tuckers rotate about the axle. Here’s a pic. You can see the carrier partially installed on the axle housing. This is a 1500 series carrier, so mid-length. Look on the differential side of the carrier in the foreground. You’ll see an arm that's perpendicular to the carrier. That arm is a rotational stop and there is another on the front of the carrier. When carriers are installed on a snowcat, those rotational stops contact the leaf springs and limit the carrier’s ability to rotate, so the tracks physically can’t hit the cab.
Here’s a different view and you can see the proximity of the rotational stops to the leaf spring packs. If you look closely you’ll see the same stops on the rear carrier. If the rotational stops have been cut off or bent, then yes, the tracks could hit the cab.
Certainly a taller snowcat will be more limited when a tree's canopy has low hanging branches. I’m tall at 6’4”, and I too am challenged in some vehicles by a lack of headroom. (I would have had a miserable time as a Navy submariner, as their door/hatch openings are not designed to accommodate even moderately tall folks.)
In the western US where we get lot’s of snow it’s not a good idea to get within a foot or two of an evergreen tree’s trunk. That applies to skiers, snowboarders, snowmobilers, and snowcats. The area close to the tree is called a tree well, and the snow there is not as settled or consolidated as the snow further away. When weight is put on it, the snow can collapse. If you’re on a snowmobile or snowcat, the machine will likely tilt toward the tree and you can find yourself pretty stuck. However, for a skier or a snowboarder, getting caught in a tree well can be fatal. This is a good description:
Kirk, I hope you have a great snowcat season!
