Since the front turn assembly is off and out of the way I decided to drop the oil pan to reseal. Below is what I found. Since this is my first time in an L6, where did this come from?? Oil pump gasket?? Did someone pull / swap the oil pump and then knock the o-ring into the pan as it was being slid back into place? Seems like it would have been leaking bad there if that was the case.
