AndreiShal
I'm considering building an AI desktop assistant for web research, document drafting, file management, and system config. The standard agent stuff.
But here's the thing: everything I see out there is over-engineered and bloated.
Complex frameworks, graph orchestrators, huge container images that take gigabytes just to search the web. There's no clean, modular app that just works.
I'm building a modular desktop application where every piece is a separate plugin that you can snap in, swap out, or remove. Think of it like Lego blocks.
Here's what I mean by "everything is modular":
Not because Java is trendy, but because it gives me:
So my idea is different
I'm not building "yet another agent framework."I'm building a modular desktop application where every piece is a separate plugin that you can snap in, swap out, or remove. Think of it like Lego blocks.
1. The interface
- Don't like the terminal UI? Swap the UI module for a desktop window.
- Don't want a UI at all? Swap it for a web server module – now your agent is an API.
- Want a messaging interface? Drop in that module.
- Want all three at once? They all work side by side.
2. The AI provider
- Using a cloud provider today but want to switch to a local model tomorrow?
- Just swap the provider module. The agent itself doesn't care – it talks to whatever provider you've loaded.
3. The tools
- Calculator, file search, web scraping – each is its own module.
- Want to add "read my email"? Drop in an email module.
- Don't need web search? Remove that module.
4. Everything runs locally in one process
- No separate containers, no microservices, no IPC calls between parts that live on the same machine.
- Just lightweight modules loaded into one application.
The tech stack
Java 21.Not because Java is trendy, but because it gives me:
- Native desktop apps without bundled browsers (no 200 MB Chrome overhead),
- Proper threading for parallel tool calls,
- Runtime module loading out of the box.
My questions to the community
- Is there a real market for a lightweight, modular desktop agent? Or are people happy with the current tools despite the bloat?
- Does "modular everything" (not just tools) matter to non‑programmers, or is that just a developer obsession?
- What's the first thing this should do well for you to even consider it?
Excellent video. Thank you Tom
