Flexiride
This is a very similar style axle setup.
They make single wheel set ups and complete axle stuff too.
The big issue is to be sure to get a spindle that will accept the size bearings used in the cat.
Flexiride make many different weight capacity sizes.
A 2000 pound size would be optimal
A set of the cartridges that have a spindle that uses 1-3/8" inner bearing.....1-3/4" seal ride surface and a 1-1/4" outer bearing.
********UNLESS YOUR WHEELS ARE THE LARGE BEARING TYPE****** but these are normally only found on the large cats 3700....4700 *********
Get your axle out and then adapt things so the Flexiride can be attached.
I looked high and low for a front axle for my 2100......nothing decent available..
These guys are a retailer for Flexiride
Trailer Parts Superstore offers a wide selection of Flexiride Torsion Axles at discount pricing. Easy to use online store with secure checkout.
www.easternmarine.com
Here are all the bearing specs for the two different sizes used
SMALL BEARING HUBS (Common on many Thiokol/LMC/DMC)
Guide wheel bearings for 2100
Outer bearing 67048
Outer race 67010
Inner bearing 48548
Inner race 48510
Seal 17617 Factory seal
USE 17607 (Double lip wider)
Speedi sleeve (SKF part 99122)
Dust caps
Napa 730-2411
Hubs...H25-555F (Complete)
LARGE BEARING HUBS (Used on the heavier cats )
Two front Wheels
Inner Race 88610
Inner Cone 88649
Outer race 02420
Outer Cone 02476
Seal 471984
