Antenna in a tree
S-noWonder
When I bought my house I noticed a wire (co-ax?) that runs up to a very tall tree. I have no idea how they got it up there. It appears to be attached to something, but it's so far off the ground I can't tell what. The end in the house looks like a large phone jack. So I am wondering if this is for a ham radio. Is there anyway to find out?
Ham radio operators were not the only ones who are prone to put antennas in trees: Citizens Band operators and Short Wave listeners comes to mind.
As far as how the coax got up a tall tree, if its purpose was to connect an antenna up the tree to a radio in the house, something was used to get a light line (think fishing) over a limb high in the tree and back to the ground. Any number of things can be used, hammer, spinning reel, sling shot, bow and arrow, potato gun……… then a heavier line would be used pull the antenna and attached coax up.
It will be difficult to determine what the coax was used for without knowing what it was attached to at least on one end. If it was attached to a radio the “large phone jack” should be a PL 259 (Google PL 259) to see what one looks like.
Without the radio, the choices of the coax use could be narrowed down a little by examining the end in the tree. If it is attached to an antenna, the size and configuration of the antenna could give a hint to the radio band it was use on. Another step could be taken. If the coax is not damaged, and if the connection to the antenna is still good and the antenna still functions, there is test equipment that can be used determine the frequencies for which the antenna was used.
This equipment is a little pricey so your choices may be to find someone (think well equipped ham) or enjoy wondering what the wire did before you come on the scene.
Keep in mind Ham is short for Amateur radio operator. In my case amateur should be emphasized. The opinions expressed herein, therefore, should not be viewed as that of an expert.
WA4FRI
very old post but a cat 6 cable for surveillance camera has a phone type jack. I am installing small dish and camera now and a second dish on my house to watch my property. it has that type of connecters. it is a short distance but to far for a cable run. 1/3 mile KF7RiN
One time I was at a friends house and he had a tree so high right in front of the house,I couldnt believe the antenna was RIGHT THE THE TOP!! (It was a thin pine tree)
They must have used a fire truck to get that up there :D (No way they climbed)
Sounds like an old antenna setup more than anything else. People used to run long wires up to trees to get better height ither for TV reception or a long-wire/shortwave antenna. The ‘large phone jack’ inside could just be an old connector or adapter from back then. If there’s an insulator up in the tree (usually a small ceramic piece), that’s a strong sign it was for radio. Either way, it’s probably no longer in use just leftover from a previous owner.
The house across the street from me has an antenna that looks similar to this one up in a pine tree. It is from back when AT&T was running out of available copper bandwidth in the area (later 1990's - early 2000's?) I believe it was a microwave-based service. It didn't last for very long. It was around the time AT&T paired up with Dish network to offer satellite-based service. Funny thing is, the tree that the AT&T contractor mounted the antenna on is in the next door neighbors yard (to the left). At time the house was a rental and it guess the renters didn't know (or they didn't care) that A&TT had run a co-ax through their back yard.
