The original AT 545 was starting to slip so I decided to upgrade to the Allison 1000 6 speed from CA Conversion.
It has been a direct bolt in replacement up to this point. The 1000 is 3/4” longer than the 545. Was able to adjust for this by changing one of the drive line/companion flanges. It happened to be 3/4” shorter. So no transfer case or engine repositioning was required. BUT the drum parking brake on the tail shaft was sacrificed. Either going to go with a mechanical caliper on the other side of the service brake or a mico lock.
We’ve got it bolted in and going back in with drivelines and steering links.
Hope to get the throttle position sensor setup installed tomorrow. (Computer on trans needs to know how much pedal you are giving it in order to function correctly.)
