Thanks for the input, Franc. What's a damper?
Just inside the wall behind the shutoff valve is a 8" pipe going vertical. It is full of air and acts as a sort of spring to absorb hydraulic pressure when the faucet is closed.
150psi! That would get your attention in the shower! I have the identical valve. There's a screen with a spring and check ball in there I guess your supposed to clean once and a while. Mine was really crapped up with sand and rust. You must have a high pressure well pump!
