Bulldog1401
Anybody seen my marbles?
If the tank is as good as it appears to be structurally, a good radiator shop can make it good as new.
Senders and gauges are matched units to a degree. Measure the resistance of the sender through its sweep. Does it appear to work O.K.? (1/2 position equals 1/2 on gauge, etc..)? if so you have a baseline for a replacement sender. If not, Napa sells VDO gauges and universal adjustable senders you can substitute. If you must use the original gauge, use a variable resistor to determine what sender values you need and go from there. Hope this helps.
