Agreed.
Both exhaust manifolds had blown gaskets and warped out of plane. The exhaust manifolds are getting planed again.
The intake manifold has an exhaust cross over and is plated off. That cross over should see no pressure but there was enough pressure to burn through the gasket under the plate.
I was just talking to my buddy here and he said it all points to a restricted exhaust.
As for the O2 it can be ran on one (the right) side, or install a cross over pipe. That’s a discussion for the muffler shop.
I also used a dial indicator to check the TDC mark and it was good, so timing was good.
