Rewiring for new washer and dryer
jpr62902
Jeanclaude Spam Banhammer
I finally bought a new washer and gas dryer. I want to redo the wiring and install a new outlet on the basement wall (versus keeping the overhead one on the floor joist). Do I need to use a GFCI receptacle, or can I just use a regular receptacle?
Pretty sure it's supposed to be a GFCI.
If you're re-doing the wiring, you may want to consider a GFCI breaker.
The receptacle has to be GFCI protected. Could install a GFCI receptacle or GFCI breaker either one.
GFCI's have been required in laundry areas since 1975,................. jus sayin
Rusty assures me his way provides a nice cozy source of central heating:yum::yum::yum:
But jokes aside don't play with that shit call in a pro to be safe.
I'm pretty sure many on this forum know how to wire up a receptacle. ;)
And to play it safe i feel the need to advise....you just never know even though i do know JPR is a smart cookie,it would only take a moron to read part thread and all kinds of shit could happen, me included :wink:
To be honest i am not sure on the regulations you have to work with but i can explain mine...
First up any wiring that is new to a property as to be certified for the property , replacing excising can be done by a home owner
each area of the house is on a separate ring so upstairs lights ,downstairs lights, up sockets ,down sockets, bathroom with shower having its own ,kitchen with oven having its own,appliances are on a fused socket of their own, and all run on a separate RCD (An RCD, or residual current device, is a life-saving device which is designed to prevent you from getting a fatal electric shock if you touch something live, such as a bare wire. It can also provide some protection against electrical fires.)
Then any out door power would run to a RCD borad of it's own like i have in the shed ect.
I play it safe and even my utility room as it's own RCD , in short we slap a power breaker to cover all areas of what could happen....any thing with water is a nightmare when attached to electrics.
I think your the same we just call it by a different name....just translate it to proper English and i can help more:brows:
PS...washers,dryers, fridges and freezers and the most common causes of house fires so taking steps to the max in these areas really does pay off.
