FS: ST4 Trackmaster and Maxey Trailer - SOLD!
utahwilson
Folks, I have decided to sell our trackmaster and trailer (16' 12k GVW). I feel this snowcat deserves a better home or at least someone with the time to work on and use. If you are Lakers fan it's blue/yellow pant job will be a bonus. I will try and post as much information as you need. However, you can always PM if it is not posted here. Price will be $11,000 (firm). This covers the cost of the trailer and the work I had done at Peterson Equipment out of Layton Utah. If you work for Peterson or related then the snowcat will cost you 25k. Currently, the cab is off as I intended to raise the cab. Also, the engine is out as I replaced the rear main seal. At this point since I am selling and most likely new buyer will want to strip it down I have saved you having to pull the engine. :w00t2: All the tires have been replaced and foam filled. I am even including a spare rear tire for your kids to play with since the tires are foam filled. I also, have two extra sprockets courtesy of Alaska. Right front sprocket had a crack and appeared to have been "bandaided". I have included some pictures and copies of the two invoices. Most likely there will be questions and additional posts. When I purchased this out of Las Vegas of all places - I was told the engine had been rebuilt as an 1835CC. Nothing to corroborate that other than it was covered in shinny chrome. Carb is a Weber. Please reply with any questions.
  • Inv_58555_from_PETERSON_EQUIPMENT_COMPANY_2320.pdf
  • Inv_58051_from_PETERSON_EQUIPMENT_COMPANY_2188.pdf
akmountaineer
Re: FS: ST4 Trackmaster and Maxey Trailer
That's a real bargain for somebody considering what's gone into it. I might have snatched it up if I hadn't just bought a different one.
redsqwrl
Bummer, it was a lot of fun co-miserating with you.
Tell me you are back in the hunt for a tucker at least.....
Now where did SE Iowa run off to.......
utahwilson
I wish (Tucker). Wife and I are looking at building a house and unfortunately shop is last on her list of priorities.
DAVENET
But should be first on yours, which puts it squarely in the middle! Just plan for a four bay 'basement' and let her build whatever on top of it! :whistling:
utahwilson
Doug, I will call you as soon as I get a chance. Here are some more pictures. No cracks in the glass. I made a quick disconnect for the steering wheel to keep the kids from playing with it. Rubber tracks are in great shape. I have included pictures of the sprockets that I was able to obtain thanks to Don in Alaska. You can see where someone at some point tried to repair. The 5 times I took the cat out it didn't fail, but figured I would replace anyway.
akmountaineer
That looks like a nicely tricked out engine. What's the stuff mounted on the fender behind the light?
utahwilson
previous owner mounted an oil cooler, oil filter and battery box on the right front fender. I added a support cable from the roof rack to the fender to help with the weight.
Beartooth
where is the cat located? Any photos of cat together when operational? I see there arent any wide side skirts on it or railing?
NorthernRedneck
Those variators look like they run the same as the primary and secondary clutch on a snowmobile
Sent from my SM-G900W8 using Tapatalk
utahwilson
SOLD: Not sure how to edit the original thread. Thanks to everyone that expressed interest in the snowcat. I enjoyed talking with folks online and also met a forum member in person. Good to know the cat will be in a good home of a fellow forums member. Hopefully in a few years I will be back in the market for another cat.
Jim_S
I edited the title.
Jim
utahwilson
Our snowcat left today for Montana with its new owner. I feel like I just sent my kid off to college. Glad it went to a forum member. I enjoyed talking to everyone that inquired about our track master. Hopefully, there will be a Tucker addition to the family in the future.
