Go Back   Forums Forums - Off Topic Forum FUN > Vehicles > Cars, Trucks Forum
Reply
Thread Tools Display Modes
  #1
Old 12-13-2006, 11:14 PM
mtntopper's Avatar
mtntopper mtntopper is offline
Back On Track
mtntopper is on a distinguished road
Default Ford Tow Command
I have a 2006 Ford F350 with tow command. The prior short time owner installed an older 6 wire round style trailer connector in the box and on the bumper for a goose neck trailer. Today I decided to build an adapter to go from the old style 6 wire round to the 7 wire large OEM type plug now being used on late models for the box plug. No matter how I wired it, the tow command came back as "trailer not connected" on the tow command readout. Now the large 7 wire on the bumper works fine on my trailer. Why can't you use an adapter from a 6 wire type plug to a 7 wire on the Ford tow command? I guess I will just have to convert the box plug over to the new 7 wire style plug and say to he_ _ with trying to use an adapter. I know it has something to do with a small amount of electrical signal sent to the trailer to confirm it is hooked up and wired properly. I just don't understand why the adapter failed to communicate the same way between truck and trailer. Has anyone else seen this problem or have an answer?
__________________
  #2
Old 12-14-2006, 06:33 AM
HGM's Avatar
HGM HGM is offline
HGM is on a distinguished road
Default Re: Ford Tow Command
You have mail..
__________________
Greg
  #3
Old 12-14-2006, 07:18 AM
Melensdad's Avatar
Jerk in a Hawaiian Shirt
I went through the better part of a year of grief with trying to figure out how to get my VW Touareg to play nice with the trailer lights. In my case it was a very simple fix, but the last fix we tried! Some of the new vehicles, perhaps yours, require sufficient electrical draw from the trailer to properly activate the tow vehicle's trailer related electronics. In my case my trailer, which worked fine with 2 other two vehicles, had LED lighting. The LEDs have very low current draw, consequently they would not play nice with the Touareg because it required more draw than the LEDs would pull, and that led to "fault" messages and flashing trailer lights. The Touareg, wired by the dealer, went back and forth to their shop (all at no charge) to get it straightened out. They never could figure it out. Finally I found the answer on a VW website.
I'm not sure if that is applicable to your problem, but it is something to keep in the back of your mind if you can't figure out the truck wiring it might be related to the trailer?
__________________
- Ayn Rand
  #4
Old 12-14-2006, 08:31 AM
jwstewar's Avatar
jwstewar jwstewar is offline
jwstewar is on a distinguished road
Well if it fixed the problem, why would you have kept trying to fix it? Remember, if it ain't broke, don't fix it.
Another thought, isn't there 2 different standards for the 6 pin connections? Maybe the truck is using the "other" standard.
  #5
Old 12-14-2006, 09:30 AM
mtntopper's Avatar
Back On Track
Thanks HGM
You confirmed my thoughts to what the problem may be with your PM.
I am going to hook the F350 up to some of my other older trailers and see if the add on 6 pin will work with them today. I have been using an adapter of 7 to 6 pin with the older trailers in the past but not on this truck with tow command. I will try both the 6 direct and the 7 pin adapter plug on the rear bumper. I was able to get a slight voltage reading yesterday at one pin of the 6 connector that I was not able to identify. It was probably the voltage pulse you mention. It was a very small signal and not consistent.
Quote:
Every 4 seconds the TBC module sends a voltage pulse along circuit 43 (DB) to trailer tow C4099-3 to determine whether a trailer is connected to the trailer tow connector. If the TBC module receives a returning voltage, a trailer is connected. If the TBC does not receive a returning voltage, a trailer is not connected.
The "CKT 43" mentioned is the dark blue wire located at pin 3(lower left/7 o'clock if looking at the female end of the 7-pin conn).. It must be connected on its own(not jumped to another or left disconnected as I suspect)..
__________________
__________________
  #6
Old 12-14-2006, 09:42 AM
PBinWA's Avatar
PBinWA PBinWA is offline
Master of Distraction
PBinWA will become famous soon enoughPBinWA will become famous soon enough
Style: VB_Original_Style
HGM is a god-send to any Ford owners on this board and TBN.
I think we need to start a collection and send him a Christmas present!
__________________
A government big enough to give you everything you want, is strong enough to take everything you have.
-Gerald Ford
  #7
Old 12-14-2006, 12:25 PM
DaveNay's Avatar
DaveNay DaveNay is offline
Klaatu barada nikto
DaveNay is on a distinguished road
I know where we can get an old rusty Dodge to send him!
__________________
Never ascribe to malice, that which can be explained by incompetence.
Napoleon Bonaparte
If God were suddenly condemned to live the life which He has inflicted upon men, He would kill Himself.
Alexandre Dumas
  #8
Old 12-14-2006, 01:20 PM
Wannafish's Avatar
Wannafish Wannafish is offline
Floppy Member
Wannafish is on a distinguished road
What's a "TBN" ?
  #9
Old 12-14-2006, 01:52 PM
jwstewar's Avatar
Quote:
Originally Posted by Wannafish
What's a "TBN" ?
Isn't that the Turner Broadcasting Network? Maybe he has a show on it or something Anyone know when it is on?
  #10
Old 12-14-2006, 04:04 PM
HGM's Avatar
HGM HGM is offline
What's a "TBN" ?
Thats something gsr1000 used to say alot..... Think its related to oil....
__________________
Greg
  #11
Old 12-14-2006, 04:08 PM
HGM's Avatar
HGM HGM is offline
Quote:
Originally Posted by mtntopper
Thanks HGM
Glad to help... I dont always have advice on things(sometimes more questions) but anytime I can help you guys with a Ford just let me know..
BTW, thanks for the offer, but I really dont need a Dodge...........
__________________
Greg
  #12
Old 12-14-2006, 04:43 PM
BigAl's Avatar
BigAl BigAl is offline
BigAl will become famous soon enough
Hey Bill,
My 2006 Ford diesel has that same set up and I don't have any problems towing different trailers . I have a bunch of trailer plug adapters in my glove box. I did have one adapter quit working correctly and scared the PeePee outta myself when I looked down at the command center and it said "Trailer Disconnected " .
__________________
Big Al
2B1ASK1
See my Kristi Video here : Kristi KT3 - YouTube
Disclaimer: Read with caution !!
Poster may be Bad Speller at times .
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
FORD: buyouts, plant closings, is it enough? Melensdad Cars, Trucks Forum 12 09-16-2006 09:09 PM
Ford Motor Company: Here we go: For Sale DAP Cars, Trucks Forum 6 08-04-2006 10:21 AM
Ford 03.5 - 2006 6.0L Turbo Diesel DAP Cars, Trucks Forum 12 06-19-2006 09:33 PM
DO NOT BE OFFENDED: Ford F250/350 Superduty Depreciation DAP Cars, Trucks Forum 8 01-21-2006 11:19 AM
Ford Fusion OregonAlex Cars, Trucks Forum 1 01-16-2006 05:17 AM
