Go Back   Forums Forums - Off Topic Forum FUN > Vehicles > Cars, Trucks Forum
Reply
Thread Tools Display Modes
  #1
Old 10-22-2006, 06:16 PM
Doc's Avatar
Doc Doc is offline
Forum Admin
Doc will become famous soon enoughDoc will become famous soon enough
Default straight antifreeze or mixed?
For those that change your own antifreeze do you dilute the antifreeze or put in straight antifreeze and let it mix with whats in the block?
As i understand it straight antifreeze is good to -40. Plenty good for my use.
  #2
Old 10-22-2006, 06:20 PM
DaveNay's Avatar
DaveNay DaveNay is offline
Klaatu barada nikto
DaveNay is on a distinguished road
Default Re: straight antifreeze or mixed?
I always dilute it. I have a jug of antifreeze sitting in the shop (diluted) and when it runs out, I buy another one (undiluted), and pour half the new into the empty old. Then I top them both off with water. This has just become a habit, and ensures that I have the proper dilution available.
__________________
Never ascribe to malice, that which can be explained by incompetence.
Napoleon Bonaparte
If God were suddenly condemned to live the life which He has inflicted upon men, He would kill Himself.
Alexandre Dumas
  #3
Old 10-22-2006, 06:23 PM
OhioTC18's Avatar
OhioTC18 OhioTC18 is online now
OhioTC18 is on a distinguished road
A 50-50 mix will give you -34 protection. I always dilute, straight anti-freeze won't allow enough cooling, or so I have heard.
  #4
Old 10-22-2006, 06:39 PM
Big Dog's Avatar
Big Dog Big Dog is offline
Large Member
Big Dog has a spectacular aura aboutBig Dog has a spectacular aura about
Quote:
Ditto!
__________________
"No law ever prevented a crime" ...........
The MLR (Men's Locker Room) is now open! PM Big Dog for access ....
  #5
Old 10-22-2006, 06:52 PM
Doc's Avatar
Doc Doc is offline
Forum Admin
I was talking with a guy from an auto shop and he said the last two places he worked at never diluted. They allowed it to mix with what was already in the block. He never mentioned any cooling issues but I didn't ask.
I always dilute (when I change my own) because i didn't think it protected the lower temps if not diluted half and half. The lasst few times though I've had them done at a shop. And I never asked them.
  #6
Old 10-22-2006, 06:56 PM
OhioTC18's Avatar
If you're changing your antifreeze, there should be nothing left in the block for it to mix with.
  #7
Old 10-22-2006, 07:42 PM
Doc's Avatar
Doc Doc is offline
Forum Admin
I never open the drain plugs on the block for the car or truck ...on the boat that's a different story .....
Do you drain your block?
  #8
Old 10-22-2006, 08:20 PM
HGM's Avatar
HGM HGM is offline
HGM is on a distinguished road
50/50 will give you the best cooling and protection as a rule of thumb.. The water will actually cool better than the coolant, but the coolant lubricates and helps to keep it from freezing..
Here lately, I've been using the pre mixed.. I'm sold on it for a couple of reasons.. Primarily for the fact that the water doesnt have the minerals and comtaminants in it that regular tap water has.. This will help reduce scaling in the cooling system build up.. Its already the proper mix and conviniently bottled for use ...
I only drain the radiator, the block is mostly empty when its drained... So, the refill is much more acurate if the coolant is premixed(by you or the MFG)..
__________________
Greg
  #9
Old 10-22-2006, 08:32 PM
Doc's Avatar
Doc Doc is offline
Forum Admin
Sounds like a good plan to stick with Greg. I also like the idea of pre mix.
  #10
Old 10-22-2006, 09:50 PM
PBinWA's Avatar
PBinWA PBinWA is offline
Master of Distraction
PBinWA will become famous soon enoughPBinWA will become famous soon enough
Style: VB_Original_Style
I like a little tonic water! That lemon spritz makes it go down just right!
__________________
A government big enough to give you everything you want, is strong enough to take everything you have.
-Gerald Ford
  #11
Old 10-23-2006, 12:28 AM
Junkman's Avatar
Junkman Junkman is offline
Extra Super Moderator
Junkman is on a distinguished road
This is the latest and greatest in anti freeze..... It will save you money in the long haul.......
Part No.
ZXGO51 Valvoline [Antifreeze] Zerex GO5; Gallon
Zerex G-05 is a low-silicate, low-pH, phosphate-free, pre-charged formula that is designed to protect automotive and diesel engines from rust and corrosion. Zerex G05 is approved by Ford and by Daimler-Chrysler for worldwide applications including all MTU and Mercedes engines.
Approved by Ford and DaimlerChrysler for use in automotive and diesel engines.
Utilizes hybrid organic acid technology to minimize inhibitor depletion
Low-silicate, low-pH and phosphate-free formula
Provides protection against liner pitting and corrosion
Helps prevent rust and corrosion
Helps prevent hot weather boil-overs and cold weather freeze-ups
Protects all cooling system metals, including aluminum
__________________
Supreme Exalted Grand Master
  #12
Old 10-23-2006, 06:00 AM
HGM's Avatar
HGM HGM is offline
The only thing that concerns me about that is that it is OAT... As in Dexcool style antifreeze .... I dont know enough about it to praise it or slam it, but Dexcool and typical OAT(orange) antifreeze is prone to geling from contamination and cavitation of the cooling system, causing major engine damage.. If your interested, do a search for Dexcool, GM is having a hell of a time getting past the use of that stuff.. Fortunatly Ford only used it breifly in two models... It very well may be good stuff, I havent heard of it yet..
__________________
Greg
  #13
Old 10-23-2006, 12:13 PM
Junkman's Avatar
This has been proven by use in Mercedes for many years. I have been using it in my Benz and have never had a problem. In fact, I have never replaced a water pump or radiator in any of the Benz's that I have had since they started using that formula. Both gas and diesel. I intend to use it in my Kubota when I change it. Junk.....
__________________
  #14
Old 10-23-2006, 01:06 PM
cj7's Avatar
cj7 cj7 is offline
cj7 is on a distinguished road
Just do not mix the two colors together... bad bad very bad... you end up changng the pump, freeze plugs
I always dilute.
  #15
Old 10-23-2006, 09:35 PM
Trakternut Trakternut is offline
Silver Member
Trakternut will become famous soon enough
One should never run straight antifreeze. First off, it doesn't cool as well as a 50/50 mix. Secondly, at bitterly cold temps, it will create a slush in the system that impedes flow.
Half-and-half mix tests to -40.
As far as completly draing blocks: Walley-World, or your favorite department store, as well as auto parts and farm supply stores carry testers. Change your antifreeze, but don't completely fill the rad or water bottle. Drive for a day to get it mixed really well, then test. Add straight antifreeze, or straight water, dependant on whether it's too strong or too weak, until the system is completely full.
You're good to go!
Tn
  #16
Old 10-23-2006, 10:49 PM
Kubota King Kubota King is offline
Kubota King is on a distinguished road
i purchase it pre mixed in the jug. It is a little more money but I have never, ever had any of my engine's over Heat! i Buy it from the Motorcyle shop, its the only place I can find it & well worth it.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Straight cuts on plywood solved. JimR Tools & Tractor Implements Forum 2 04-22-2006 11:53 PM
Straight to the point TOMLESCOEQUIP Political Debate Forum 2 01-13-2006 09:59 AM
