Reply
Thread Tools Display Modes
  #1
Old 10-31-2012, 06:19 PM
64Thiokol1201 64Thiokol1201 is offline
Junior Member
64Thiokol1201 is on a distinguished road
Default 1964 Thiokol Spryte model 1201
Hello, I am a new poster. I am looking at a 1964 Thiokol 1201 with the Ford Industrial 6 cylinder. Any specific items I need to inspect prior to purchase??? Other than the motor which I am familiar with. Thanks for any help.
  #2
Old 10-31-2012, 06:23 PM
Snowtrac Nome's Avatar
Default Re: 1964 Thiokol Spryte model 1201
always look at the condition of the road wheels,suspension components drive sprokets and most important is the condition of the track and belts rebuilding a track can get expensive and be labor intence
__________________
Don
1962 st-4
KL2ZF
  #3
Old 10-31-2012, 09:51 PM
Dr. Zaugg Dr. Zaugg is offline
Dr. Zaugg is on a distinguished road
If the present owner will let you, I would drain about a cup of oil out of the center drain on the differential housing and a little less out of each of the drop boxes. This could show you metal filings or bearing bits. OR if the guy is super cool you should pull the rear cover and take a peek. Sometimes the pinion gear is very worn with no other way to know other than sight. (they break off too) Very expensive in there!
  #4
Old 11-01-2012, 11:10 AM
Junior Member
Thank you for the quick response. I am going to inspect next weekend and purchase if OK. The time window to inspect is very limited. Are drive train parts hard to find even if expensive? I heard the drive train is all Ford parts and therefore available, is this correct or wishful thinking. I can handle just about anything mechanically I believe, so the cost would be in the parts and the effort to locate them. The current owner says the tracks are rebuilt (new belts) and that he has gone through the entire machine mechanically. I'll ask what he saw in the gear box but I do not think he will let me pull the cover. If the machine is all he says it is, any idea what the current market price is for this machine. It is a flat bed, ford industrial straight six, manual 4 speed, 2 person cab with large center console. Cosmetically my wife would call it a junker, but I am blessed with the ability to see the inner beauty. I am extremely excited at the possibility of of owning this machine, so I want to be certain I am looking at it objectively, and not getting into something that turns into a lawn ornament because I can't find parts.
  #5
Old 11-01-2012, 12:27 PM
Kristi KT7's Avatar
Kristi KT7 Kristi KT7 is offline
Formerly IronGoat
Kristi KT7 is on a distinguished road
wher eis it located and do you have photos
  #6
Old 11-01-2012, 01:38 PM
Junior Member
Out at secret creek. Any help with my rookie questions?
  #7
Old 11-01-2012, 04:09 PM
Snowcat Pat's Avatar
Snowcat Pat Snowcat Pat is offline
Snowcat Pat is on a distinguished road
I have yet to open a thiokol/LMC diff that did not have something wrong in there.
OC4 ring and pinion are very expensive, 1200A drop box parts hard to find. You've been informed.
-Pat
  #8
Old 11-02-2012, 10:17 AM
Junior Member
I gather this means the ring an pinion is not a standard 1964 ford drive train part?? Any idea on current market value for this machine from anyone out there? A range is Ok based on the basic description above. Thanks for all your input.
  #9
Old 11-02-2012, 05:46 PM
undy undy is offline
undy is on a distinguished road
64,
Short answer is, "whatever someone will pay". I'm only new to this snowcat problem, so I make no claims to be an authority. However my advice is worth what you are charged for it too.
My Bombardier 252 also has a Ford 300-6 drivetrain, but the end of the tranny is about it for Ford. Like most 30+ y.o. vehicles, that doesn't mean it is easy to source even engine parts. For instance, it's a 1978 model cat, but appears to have an earlier engine because it's got breaker points, which I believe the Ford auto engines didn't. It's also got a 'rebuild' tag on the block, so who knows??
But the differential in mine is decidedly NOT Ford. IIRC, the OC is Oliver-C_____ (as in tractors), but even this I'm pretty sketchy on.
So if one of these other guys writes that it's got expensive parts, and offers advice on how to go about confirming the condition, I'd guess it was hard-learned info on someone's part. Because of the price and scarcity of parts and the really high labor input on things like tracks, the current value probably ranges from scrap metal/parts cat on up. You can get the local scrap value from a recycler.
It might be wise to consider the condition you ultimately want it to be in and how much you'd have to spend to fix this one up that nicely. Don't buy a turd and expect to make money polishing it up. Like collector cars, it's probably cheaper to buy one someone has already fixed up than to do all that work yourself. But if you're comfortable with a "rat"-cat and this one is sound mechanically, then who cares how it looks and you might get a great deal on it. In that case, as close to scrap value as possible is ideal.
  #10
Old 11-02-2012, 06:19 PM
wade2367 wade2367 is offline
Junior Member
wade2367 is on a distinguished road
If you need any drive train parts I have a complete drive train from my 1969 1200 a. Call with any questions Wade 801-450-8143 SLC, Utah
  #11
Old 11-02-2012, 06:27 PM
if the thing is reasonably compleate and starts and runs it's got to be worth 5 k tough to tell with out pictures but again you have to look closely at the tracks grouser and belt replacement can get expensive fast and as these are high wear items some of the stuff for older riggs are starting to be hard to come by
__________________
Don
1962 st-4
KL2ZF
  #12
Old 11-03-2012, 11:45 AM
Junior Member
Thank you all for the great information which should be enough to keep me fom obtaining a very expensive lawn ornament. If I purchase the machine I'll post pictures. Sounds like there is a wealth of knowledge on this forum and I hope to join the snow cat community shortly.
  #13
Old 11-03-2012, 12:15 PM
muleman's Avatar
muleman muleman is offline
worn out farmer
muleman is just really nicemuleman is just really nicemuleman is just really nicemuleman is just really nice
You don't have to buy it to post pics. Always looking for more pics.
__________________
"The strongest reason for the people to retain the right to bear arms is, as a last resort, to protect themselves against tyranny in government"
  #14
Old 11-03-2012, 12:51 PM
Junior Member
Unfortunately I do not have any pictures yet.
  #15
Old 11-25-2012, 11:15 AM
Junior Member
Thumbs up Re: 1964 Thiokol Spryte model 1201
Here she is folks. The latest addition to the family. Can anyone help me decipher the ID plates in the attached photos? I have also located drive train parts from Wade in Salt Lake City Utah and would like to get them to Sacramento California. Anyone have a reference for a reliable shipper that will crate a motor and OC-4 drive axle and ship to me? The crate would be approximateoly 8' by 4' by 4' maybe 1,500 Lbs.
How do I get a .jpeg file size down to less than 302.7 KB to post photos on this forum so???
  #16
Old 11-25-2012, 11:27 AM
muleman's Avatar
worn out farmer
can do it in paint. I use this.
PIXresizer - CNET Download.com
__________________
  #17
Old 11-25-2012, 12:06 PM
Junior Member
Thanks muleman. Pictures now resized, still says invalid post, security token missing. Sent message to administrator.
  #18
Old 11-25-2012, 12:14 PM
muleman's Avatar
worn out farmer
Never saw that before. I did read about it once before though.
__________________
  #19
Old 12-14-2012, 07:39 PM
dave_dj1 dave_dj1 is offline
dave_dj1 is on a distinguished road
What ever happened to the pictures?
  #20
Old 12-15-2012, 10:15 AM
Junior Member
Here they are...... Ordered a spare drive train from Wade in Utah, looking for 6 way plow attachment for grooming back country trails on side slopes. AAA can't help where I am going if I have a mechanical problem. I figure with one spare complete drive train, I can swap out any part in the field.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1201 thiokol spryte 59muskeg Snowcat Repairs, Parts & Problems Forum 2 07-03-2011 05:30 PM
1201-41 thiokol spryte Upnorthfishing THIOKOL/LMC/DMC Technical Issues Forum 17 02-05-2009 04:58 PM
SPRYTE 1201 for sale Penn. no reserve!!!! socal4t12 Snowcat Restoration & Modification Projects Forum 2 11-13-2008 09:23 AM
Thiokol Spryte A-Model gs_adventure THIOKOL/LMC/DMC Technical Issues Forum 23 03-12-2008 11:55 PM
1964 Thiokol Spryte on ebay NorthernRedneck Snowcat Adventure & Usage Forum 2 08-22-2007 01:08 AM
